Error decoding/encoding/sending the specified message from/to the remote peer.
Communication between application peer failed due to error when decoding/encoding/sending the message. If it persists, an application restart or switch reboot maybe required to correct the problem and contact technical support, providing outputs of 'show switch', 'show log'.
Error
Error %action% %msg%: Length %length% Peer %peer% (%name%)
| Name | Type |
| action | String |
| msg | String |
| length | sInt32 |
| peer | uInt32 |
| name | String |
